Submission instructions
Submitted papers must not substantially overlap with papers that have been published or that are simultaneously submitted to a journal or a conference with published proceedings. Failure to clearly identify any duplication or overlap with other published or submitted papers is ground for rejection without full review.
Papers should be submitted in Portable Document Format (PDF). Papers submitted in a proprietary word processor format such as Microsoft Word cannot be considered. At least one coauthor of each accepted paper is required to attend CSF to present the paper.
Papers may be submitted using the two-column IEEE Proceedings style available for various document preparation systems at IEEE-CS Press. To prepare your submission using LaTeX you should use the files IEEE_CS_Latex8.5x11x2.zip and instruct8.5x11x2.pdf and begin your document with
       \documentclass[10pt, conference, compsocconf]{IEEEtran}
Papers should be at most 12 pages long, not counting bibliography and well-marked appendices.
Committee members are not required to read appendices, and so the paper must be intelligible without them. Papers not adhering to the page limits will be rejected without consideration of their merits.
Submit papers using the CSF 2011 submission site
http://www.infsec.cs.uni-saarland.de/csf2011/
 Home
                   Home
